The GTX is very stable it will be night and day compared to the wave raider. I rode a friend's raider years ago and it's definitely not a 2 person ski. Was OK once you were moving but very tippy at slow speeds. I've never been a fan of that hull even with one person though.
The GTX you really have to try hard to tip it over. I can stand on the back corner fishing off of it with no issues at all. I like the ski because it's still somewhat playful while being stable and still hits the mid 50's for top speed.
Just make sure you go through the typical seadoo preventative maintenance before riding at all and it should be a great ski for you.
Here are the basics:
- check fuel lines (replace if it still has original gray lines)
- clean or rebuild both carbs
- replace fuel selector
- check fuel strainer and ensure the o-ring seals correctly
- clean rave valves and check o-rings/replace gaskets
- check wear ring clearance and replace if needed.
- change jet pump oil
- change spark plugs
- replace oil feed lines from tank to oil pump, tank to Rotary valve cover, and from under exhaust back to tank.
- replace the small 3/32 oil injection lines with new tygon lines and bleed oil pump (unless someone has changed the ski to pre-mix)
- ONLY USE api-tc low ash 2 cycle oil. You cannot use cheap tc-w3 oil like in the yamaha. If you are unsure of what oil is currently in the tank you need to drain it, clean, and refill with the proper oil.
This is the minimum I go through with any ski I buy before riding. Good luck and post questions if you've got them.
