3whitesands
Here are the pics from my installation of my Hawkeye Depth Finder. I installed this into my 2004 Seadoo Sportster 4-Tec. The manual is easy to follow and if you follow it, you will have no issues. You will need a "wire snake" to fish the wire from the storage compartment (located behind the steering wheel) through the hull into the engine compartment. I used a Dremel to sand down the area where the transducer is glued in which made it an easy process. Others have posted their installation pictures with the same unit and since I found their info very helpful, I felt obligated to share my info and pictures as well. If anyone has any questions, I would be happy to help you out if I can.
