flyingarmy
Picked up a Hawkeye D10D from Norcross Marine.
I have already installed the guage in place of the accessory plug on the dash. I haven't re-installed the accessory plug yet, looking for a good location. I tried many different configuration for the transducer and after reading all the threads about issues with installing it "in-hull" I have decided to go ahead and install in on the transom. I have been very leary about drilling through the hull, especially below the water line. But after several brainstorming sessions and looking at different ways, I saw that the speedometer sensor cable is routed through the transom plate using a wire compression fitting on the port side. The starboard is also set up to use a compression fitting but it's not drilled through the hull. My plan it to use that hole to feed the wire through and use a Ancor 3/8" wire seal to prevent water leaking. I have used these fittings in the past in my salt water reef hobby and they work great. I looked how the other fitting was sealed and I will do the same on the other side. The transducer end cable end plug won't fit through the Ancor wire seal so I had to cut the wire to feed it through. The Hawkeye manual only states that cutting the plug at the guage will void the warranty, actually you cut the wire on the transducer if you need to lengthen the cable. This morning I'll take some pictures of the install and also of the gauge I have already installed.
