help? Can I lub parts. HELP!? Seadoo starts and runs well, but Seems internal parts of carb sticking. Can't access w/o alot of work. Can I lubricate without taking apart? Any other suggestions please.
give it a shower with carb cleaner the better brands also contain a lubricant that will stick to parts
worst case is that theres a burr on the valve body that is causing the sticking
It could be that the bushings on the carb lever( butterfly) is sticking. If you can look at the linkage is it snapping back to idle?(engine not running) If not remove the throttle cable. Try it again. If it still doesn't you have to remove them and check the bushings on each side of the throat. They might be able to be freed up with some PB Blaster sprayed on them over a couple days and working it free. If not you have to pull the linkage out and replace the bushings.
