Happy Weekend
Mstone9942
Few new small decals added and a question regarding fuse box.
In first pic you can see the small male post 1 & 2 don't have a female connected to them. Something surely needs to be connected here. My shop book and parts catalog doesn't explain the wiring at all just the size fuses that correspond to deck lights, bilge air gauges etc. Shouldn't there be something connected on post 1 & 2 in top lefty and corner beside the 1 main black box?
Let me know what y'all think about these Seadoo decals. Not sure if something was originally on these or not
Also of anyone has a fuse chart that says what size fuse needs to go to each would be awesome.
Ps In pic gauge fuse is out I know
That white sticker should tell you the fuses, and size.
The spade terminals don't necessarily have something connected. On the Merc boats... there was basically 2 fuse blocks, and there aren't always things connected. OR... the spade on the block is for accessory gauges. On my islandia... most of the terminals aren't used.
As far as the wiring diagrams... yes... they suck on the Merc boats. Basically... half of the wiring is Merc, and half is Seadoo. (that's why there are 2 beepers in that boat) So... you need both manuals, and try to decipher it.
Thanks I will check them but so far just the 12 V outlets were blown which I assume is the outlet beside the radio. Gauges not working along with fuel has to be something simple though. I will keep digging
No worries, my utopia had several empty posts & even blank fuse holders. I managed to add fuses & connectors for extra outlets, fish finder, trim system, and a merc monitor. I think I am full now.
Some are powered by the batt switch, others through the ignition key. If you add accessories, be sure to know what circuit you are powered by.
