Rabid Active Member Sep 1, 2021 #1 I need to get some new hand grips. Anyone have some suggestions on material or design?
AKnarrowback Well-Known Member Sep 1, 2021 #2 Hockey tape. I use it on all my machines. Not the best looking but works good.
mikidymac Moderator Staff member Moderator Sep 1, 2021 #3 You can still buy the oem grips for $28 on Amazon Seadoo Grips.
tobytd Well-Known Member Sep 1, 2021 #4 Look at your grips carefully… two types. One type uses a machine screw, the other uses a sheet metal (wood) thread. Machine screw type has a hex made into the grip. They WILL NOT interchange.
tobytd Well-Known Member Sep 1, 2021 #5 295500110 … 1999 and up. Sheet metal screw 295500691 … 1998 and down. Machine screw
mikidymac Moderator Staff member Moderator Sep 1, 2021 #6 Pretty sure it is just the hardware that is different? I am using the same Amazon Seadoo grips on my 1996 skis and 2001/2004 skis.
Rabid Active Member Sep 2, 2021 #7 I will check out the grips in the skis when I get up there tonight. I have never really looked at them
Rabid Active Member Sep 2, 2021 #8 AKnarrowback said: Hockey tape. I use it on all my machines. Not the best looking but works good. Click to expand... Riding on the river that extra grip has got to help.
mikidymac Moderator Staff member Moderator Sep 2, 2021 #9 The other ones I really like are the ODI Ruffian lock on grips but they leave a gap on the seadoos because of the plastic switch housing design.
