i put a new set of plugs in started it up ran good applied some throttle got up on plane, ran up to 7000 like a raped ape then it started to cough and backfire so i backed off the throttle. so i unplugged the red wire from the rectifier in the gray box and tried it and it didnt change anything,still backfired or coughed, it does it pretty consistant when the throttle is wide open so i pulled the choke up just thinking if it was starving for fuel it would recover but all doing that did was made the motor bog down and almost kill,it seems when i first take it out it runs pretty good for a couple of minutes up to 6500 rpm then after like 5 minutes of coughing and sputtering it has a real hard time even getting up on plane, not sure if that is because i put new plugs every time i go out or if there if a fuel issue with the small filters, minnetonka4me showed me yesterday how small those damn things were, so now either i go into the carbs or pull the magneto cover and check for metal shavings like drhonda said, any suggestions? if it was fuel it wouldnt make it back fire would it? everything inside the grey box was very clean and dry as well, im stumped fellas
