First thanks for taking time to read the thread
I need some guidance. Took my 95 GTX out on the water with my little man and was going great. Next thing we know we heard a thud, and the engine died.
Basic troubleshooting, and couldn't turn the engine. Tried by hand eta nada, so towed back to the shore and threw her on the trailer to look at when we got home.
So started ripping her apart and found the issue (or issues I guess as it may seem)
I purchased the ski used and it looks like when the last person did the carbs they didn't use locktite. Apparently one of the screws came lose, and found its way down the carb and was lodged. I was able to find it and remove it after removing the carbs. When I did that I felt a door almost spring shut. (for reference I assume thats the rotary valve?)
I put the carbs back in and also had ordered the top part of the intake as apparently I was missing pieces and started her up. It was rough at first, and after giving it some gas, engine seems fine. BUT....now It seems to shoot a decent amount of oil out of the exhaust that continued after turning it off. I never let it run for more then 30 seconds off the hose. Its not a ton of oil, but a decent puddle that I have never had seen before.
I assume a seal or something is screwed up, and can appreciate any guidance. Sorry for not giving more proper terms as I am a rookie at ski repair, but reading almost all the threads on the board daily and learning a ton. I am going to perform a compression test today to see what I am dealing with.
Thanks again for reading, and thanks in advance for any advice
