Gritzlor
Hey all, I’ve been chasing a lean issue on my wifes 787 RFI for a good while. Fried a top end, then again and the crank with it.
This time I installed EGT probes as I rebuilt it to enable troubleshooting.
As we were breaking them in(I always rebuild the pair if I do any significant work on them) hers was way hotter than mine, so halted break-in.
Troubleshooting mode.
Temp sensors OK.
Replaced air intake pressure sensor(old one had given in, got it replaced with one from a 1999 GSX which is a different item but I thought they were interchangeable), got a brand new one from europe with right part#.
Found no obvious issue with the TPS, replaced anyways with an aftermarket one…bad move…old one going back in.
Gage on fuel pressure on the lake. 58psi flat.
Flow tested injectors, they were within 1.5% of each other.
Water tests inbetween changes, the only thing I got to make it run semi okay was replacing the temp sensor with a 4kOhm resistor. Still it ran temps high around 3200RPM and misfired around 4500 but temps were fine over 5000RPM.
Worst I got was 1050+ Fahrenheit under basically no load, still the sucker ran.
Without the EGT’s I wouldn’t have had a clue.
Been crawling the threads everywhere until I came across someone who had a crack in the rotary valve cover causing hard-to-find lean issue on a carbed ski. This lit the bulb.
Tore off the throttle body and inspected the rubber gaskets it sits in. The gaskets are 23 years old and there are tube spacers on the bolts capping the compression to a certain displacement.
Put the throttle body on a spare rotary cover flange I had, blocked the Y holes and blew some compressed air in. WD40 bubbled on the outside of the rubber seal.
Voilá! Vacuum leak!
Ordered a couple on Amazon for $15 each.
Crossing fingers this is all, and that I won’t have to tear the top off to hone it again and put new rings.
This issue has been bothering that ski for a long time now, probably 3 years or more, I hadn’t nailed the issue before but was determined to find it since I got the probes in.
Never rebuilding a 2Stroke again without tapping in probes. It’s less than $100 in parts for 2 probes and a handheld gage, and not a big deal when the exhaust is off.
I hope someone can use this info. I’ve gathered more insight in the RFI fuel system than I ever cared to and then it was a stupid vacuum leak after all…or I think so. Will repost if it wasn’t the answer.
Happy Sea Doo season y’all!
Temp sensors OK.
Voilá! Vacuum leak!
