Want to say hello to everyone first as I just entered this sport last week as well as this forum. Thanks to JPX, KustomKarl, and SeadooSnipes for all the previous info I have already used to help me troubleshoot this problem.
Bought 96 GTX last weekend from a very honest guy I knew previous to purchase who owned it 10 years. He has top end rebuilt about 4 years ago he said and had the guy leave the oil screw out a bit so it wouldn’t run so hot and lean and be more reliable. Every season since the first time in the water it would bog or seem to load up so his resolve was to restart with WOT for 1-2 seconds and then it would run fine. He showed this to me when I test rode as it was the first time launched this season. It worked great and I proceeded to run it as hard as I could for 20 minutes to make sure it ran smooth.
First time I put it in the water the problem got so bad I couldn’t WOT at all. Would start bogging after 3-4 seconds of WOT and get worse every throttle 5k, 4500, 3500, ect ect. I have since replaced correctly gapped plugs, cleaned fuel filter, cleaned rave valves, removed together and cleaned filters in carbs, cleaned fuel selector valve and replaced all grey lines outside the tank.
Problem has become less often but still frequent when selector is “ON” position more then when its “Reserve”. When on “reserve” after a minute or two I could get it to run WOT at 49mph, 7060 rpms as well as vary the throttle at any rpms with just a small misfire still at 4k but will increase right past it no problem. Idle is a little low I think at 1300rpms. I pulled selector apart using small set screw but didn’t know if maybe they can go bad (rubber inside them or something). Also tried to remove in tank unit but couldn’t get it loose even with both clamps removed. Is there something in the tank that could cause this… maybe something with the “ON” in tank line. Also when I cleaned the RAVE valves one is newer with two grooves in it and a green rubber baffle where the other is flat with no grooves and a red baffle. This one was completely clogged and wouldn’t open at all with baffle half off when I cleaned them they are both moving freely. Which should I have?
Sorry this is so long, I never post on forums but wanted to state everything and see where to go from here. Thanks for all the help already this forum rocks!
