FearlessFarley
This afternoon I flipped for the first time (15 year owner/user of various SeaDoo's) and was unable to right my 1997 GTX. I was near the dock so was able to swim it water logged to the ramp, winch it up and pump it out. Battery was dead so I charged it while I pulled the plugs, ran the engine to squirt the water out, put a few drops of SAE 30 oil in the cylinders, ran it some more (using the start position on my charger for power) while it continued to squirt mist out of the cylinders. Dried the plugs and an hour later repeated the starter action, still some mist but not much so I replaced the now dry plugs and tried starting. It kicked a few times while repeatedly trying to start it and then it went completely dead. Not even a weak battery click.
Is there a circuit breaker somewhere on the engine? Hopefully....
As well, a neighbor told me that I may have been trying to right it by flipping it the wrong way (it turned turtle when we dumped) which is why it filled with water which it is not supposed to do. Since I bought this used SeaDoo just a few weeks ago I do not have the Owners Manual. So, I need to acquire an Owners Manual for future problem solving. Meanwhile, hope you can help me with the three issues:
1) Which way should 1997 GTX be flipped once it has turned turtle?
2) Is there a circuit breaker on the engine like there is on other marine engines that will trigger if there is a reverse charge hook up or in this case maybe by shorting do to being submerged in water?
3) Where is best place to buy an Owners Manual?
Thank you for any help you can give me on any of the three items.
Jack Farley
Candlewood Lake, CT
jufarley@optonline.net
Jack Farley
Candlewood Lake, CT
