smarkhauser@yahoo.com
My 2004 gtx 4 tec will not start unless I put pressure or jiggle the plug connected to the mpem. Once running it will stop while on route and I will have to unplug then replug the mpem to get it working again. If anyone has experienced this issue can you tell me if it is the connection pins or the mpem itself that may be the issue? Is there a solution to this problem that has worked for anyone? The machine is in perfect working order otherwise.
