GTS bogging out
chipann
I have a 1998 GTS. It will idle and run at half throttle. When you give it full throttle it cuts in and out. i checked fuel filter and replaced the spark plugs.
Thanks
Have you tried changing the fuel selector from Gas to RES to see if you get the same problem? I had a similar issue and it was a faulty fuel selector switch.
