hockeymd
My 2017 GTR 230 lost 20mph off the top speed from last year. I purchased the 2017 GTR 230 used last year. Ran great in the Summer and hit 65mph before I put it on the trailer last Fall. I had the local dealer winterize it. I removed and stored the battery inside the house (I don't like to store batteries in unheated storage during our cold winters). I had to replace the battery right away this Spring anyway as it just couldn't hold a charge. Has fresh 91 octane (non-ethanol) fuel.
This Summer my GTR top speed is suddenly down from 65mph to 48mph. With the learner/trainer key its even slower. Starts and runs smooth. Doesn't sound like it's hitting a rev limiter or cavitating. I can pull up an adult male slalom skier so it isn't particularly weak but may have slightly less acceleration by my seat-of-the pants measure.
I've visually inspected the exterior of the intake and the nozzle output and don't see any obvious obstruction or damage.
I'm looking for possible causes of the drop in top speed with a priority on 'most likely' and 'easiest to check/fix'. After some research I've found the following possibilities. I'd appreciate your advice.
(1) throttle cable needs adjustment
(2) bad spark plugs
(3) wear ring damage/wear
(4) SuperCharger failure
(5) electronic limiting from some problem with the DESS key fob programming
(6) something wrong in the output Venturi nozzle causing water to be ejected elsewhere (I read about someone had a bolt come off?)
Thanks
Mark
(2) bad spark plugs
Thanks
Mark
