I'm new to the PWC world, and honestly pretty frustrated at this point. Hopefully someone has some idea what might be going on here. I purchased a 2011 GTI SE 130 about 2 weeks ago. I recently discovered the steering wear rings are broken and the steering column is cracked. These haven't prevented use and the parts for repair are on order. Today I took the ski our for a ride, and after about an hour and a half of running up and down the river it just died. I was at WOT and all of a sudden it died. It slowly dropped RPM from WOT to idle over the course of a second or two and then the engine died. After this it wouldn't start. I was towed to the ramp and loaded up. When trying to start it clicks and "thuds" once as if it wanted to turn over but doesn't try anymore than that. I have the battery tested and it was fully charged and at the correct CCA. From my research it sounds like the starting issue is the starter solenoid BUT I don't understand how this would have anything to do with the ski dying while running??? There are no warning lights or messages. I have a new solenoid on order but I have a feeling it won't solve the issue or will only address part of it. Your experience and help is appreciated!
