GSX to challenger 96 to 96
No the Challenger came with a cable driven reverse bucket. It mounts on the nozzles and diverts water when engaged.
Ya I had a look at 1. I see what you mean. I got a 96 Challenger for $400 with a trailer. No motor or jet pump but I have a gsx to take apart. Hopefully not a challenge lol and everything else is the as the owner says.
Just make sure you get the engine and shaft properly aligned. The engine usually uses shims to line up with the pump
Well I got it. Cleaned the he'll out of it. Everything works electronic wise. Mpem is good. Just need to add the reverse bucket to my engine and jet pump and all should be good. Thanks for the info and will definitely look at the shift. Time to yank the motor and get it rebuilt
