peter Nosbor
I have a GSX 97 with a 787 engine.
The motor starts easily and idles okay.
The RAVE values are reasonably clean and can move.
I have run the engine without the RAVE covers and can see them move to a move open position as revs increase.
The problem.
The engine revs to approx 4,200 and then begins to backfire badly.
Note: Holding the RAVE valves closed (with the covers off) seems to make it a bit better, but only marginal.
I have a recently replaced the MPEM and found this did not change the situation.
The carby was overhauled by a jetski mechanic and the machine has backfired ever since. Is it possible the rotary valve is out?
Can someone help me with this problem.
By the way I now have a good spare MPEM for a GSX97 278 001 201 for sale.
Also, the baffles in the water box are on their way out but there is no restriction in the exhaust air flow.
The problem.
