The engine is still backfiring through carb when opening throttle. I've overhauled carburetor and tried several adjustments to smooth things out but nothing helps. Engine ran strong the last time on water until it died and stranded me on lake. Carb goop really bad but did a rebuild kit and cleaned everything. Fuel lines replaced too. I've not changed any settings except low speed screw but always return to spec forum has told me to use which is out one and one quarter turns. High speed screw is at spec 0 turns.
No other electronics changed from when engine died. Engine will fire right up and idles normal.
I have some mechanical background and am confident with the carb overhaul since I had such great help on the forum. Thanks to all who guided me.
What are the reasons this thing would be backfiring through carb after the overhaul? It was not doing that before the engine died on the lake....ron
