Grease sert on 230 challanger
slide00
Can't see anywhere to grease the PTO in the engine compartment does anyone know if there is any, thanks
On my challenger there is a gray cover near the rear of the boat that comes off with 2 nuts you can just remove by hand.
I'm not real good with the newer 4-tech engines... but as I recall... you don't have a grease fitting. The PTO is in the flywheel, and gets lubed via the engine oil.
Hopefully Chester will chime in on this one.
