Hi , Seadoo has its own brand of shaft grease.
I believe the floating bearing can get quite hot on these also.
So using the correct grease will keep it right.
I also try and use all the seadoo products I can, but being 75 miles away from my local dealer, I found by reading the manual, that you can use an alternate synthetic grease. Only lubricate till you see slight movement in the boot.
