how about instead of replaceing the entire fuel system, you simply check/replace the fuel filters for christ's sake. you people kill me.
Well, Mr. revereamg, there are 3 or 2 things you don't understand. When I got mine, back in the summer, it ran great, then, it would not take more than 1/2 throttle. Then, it would barely plane. I limped back to the truck/launch area.
I then posted my first post. They all said REPLACE THE GRAY FUEL LINES.
I was skeptical. I thought about it for several days. Then, I went and looked at the ends of the gray lines, beside the clamps. There was a green glue goop there. The advice from this forum was 100% right. Those gray lines were disintegrating into the fuel, and clogging every filter in the system. I took the gray hoses off, cleaned out all the filters, and the carburetor. Now, she runs fine. I still have the gray fuel lines, hanging out in the yard. Would you like some digital pics of the GLUE that they produce, as they disintegrate?
So, I know 2 things. There are skeptics about the gray hoses. And there are converts. And the convert's skis run better than the skeptics. Unless you clean the filters REAL REGULAR, and disassemble the carb (s) and clean those out too. And, I don't have time for that. Well worth the price and time to put good new fuel lines in it.
Also, a LEAN 2 stroke motor is not a HAPPY 2 stroke motor. There are OTHER bad things that will come with a lean condition. Like OVERHEATING, and scorched cylinder walls. And shortened engine life.
Take your pick. I like nice clean fuel lines, that do NOT disintegrate.
Respectfully, and Cheerfully
Nate
