Your picture isn't working... but yes, water will come out the exhaust.
On that note........
The constant alarm is over temp. AND, generally, a garden hose doesn't have enough flow to keep your engine cool. So, I hope you didn't run it long with the alarm going off.
As far as the high idle... Get into the side of the engine and make sure the linkage isn't binding. You should be at 1000~1100 RPM.
I don't know what you mean by the jet didn't kick in. Your drive shaft that turns your impellor is always turning when the engine is running. It does not have a real neutral like a outboard. We have a reverse bucket that drops over the jet stream to redirect the jet flow under the boat. When bucket is half up and down, that is neutral. As doc mentioned, the garden hose is not enough for the water flow in most cases. You can take your boat to a boat ramp ( not during busy times ) and back down enough to submerge the pump and try again with running engine. Your idle will probably drop since you are under a load since impellor is still turning water even though reverse bucket is in neutral.
HI. I am new to the murcury engines but it doesn't look like much water is coming out. When mine is on a hose and running water gushes out everywhere. Is it possible you have a blockage in Your cooling path somewhere. May explain why you are overheating. Or maybe 3000 rpm with low water pressure from you house tap?I shut it down within 20 seconds of the alarm.. It just seemed weird that when I gave it throttle, the Roma went down.. It also seemed like the jet didn't kick in.. View attachment 37784
I know In The pic it doent look like a lot of water, it its comming out the bottom pretty good.. I'm going to take it to the boat launch tomorrow am
I have never done it myself but I read a post where the guy had created an adapter to put his compresser on the end of the line and force some sort of lubricant down the line. It may have been the steering cable and it might have been a Rotax style seadoo. I think the consensus was it's just better to replace the line.Not today.. Is there a way tolubd the throttle cable??
