Got fault code P1520
ravekiss
Took the boat out today, went through the no wake zone fine but as soon as we sped up, got a beep with the fault code P1520 and Oil Pressure warning also the engine went limp. I did some searching and cant find that code but did find out the P0520 was a faulty oil pressure switch. Where is this switch located? Am I right in assuming this is the problem?
Did you ever figure out officially what code p1520 was for? Was it your switch, sensor or other issue. I'm asking because I'm dealing w/ the same issue. around 3500rpms I'll get a oil light indicator, alarm and code.
