230WakeOwnerDallas
So I took the boat out and I'm proud to say that even in super choppy waters the tower had minimal shake. Tightening all of the bolts extra tight (*even without using locktite yet) seemed to really help the problem. The tower barely shakes at all. I'd say 0 to 1 inch in extreme chop. Completely changes everything...makes a big difference.
:hurray::hurray::cheers:
:willy_nilly:BUT...everytime I take the boat out it's always something....
Now I can't figure out how to empty the starboard side ballast bag. :banghead::banghead::banghead::banghead:
There is definitely a problem and I just cant figure out where it is. I checked my fuses behind the main battery switch. The operators manual says the ballast pumps have 2 20 amp fuses. All of the 20 amp fuses are fine. But there was a 5 amp fuse that was blown.
I replaced the 5 amp and tried to pump the water out (yes the valves are open in the vertical position). The fuse blew again. So I then put a 20 amp fuse in and got nothing. Eventually that fuse blew as well.
So now my boat is leaning to the right like no other and I can't safely haul it anywhere with all of the extra weight. :ack:
Any insight is appreciated.
Thanks,
-Matt
Thanks,
-Matt
