Jerseyjers
Seadoo, I have a love HATE relationship with u guys! Love your machines but HATE that I can't find much if any info on fault codes. Why do you people make it so hard for us owners! As an owner of many waverunners I prefer to do my own work. Gives me an excuse to get away from the wife.
Well anyways here is my current issue with my headache.
2012 rxt is 260. Faults codes c0073, c2102, and p1661.
P1661 I saw somewhere it's a bilge pump short? I have a bilge pump??? What? I don't think so, all though I've been wrong before. Just ask the wife.
C0073 is an ecm software issue, needs update? Is that correct? If so why does it need an update? It's not connected to the internet and ecm isn't getting other updates. I just don't understand why it needs and update if it was working correctly for the first 62 hours.
C2102 ibr actuator moment? Does this code show only because it faults? My ibr system moves freely I really don't see an issue besides whenI'm hauling ass and it faults causing a noose dive. Not good when your standing and wake jumping!
If anyone could help me out I would greatly appreciate it.
- with the engine running, The engine light is still on and throwing P0106 & P1106. Even though it started right up while on the trailer on the hose, it was very hard starting in the water. Once I got it running, I let it run for 5 minutes at my dock- it has a rough idle and smells rich to me. I decided to take it out for a test run- I noticed it was rough and unresponsive the first 1/4" of throttle, then it lurched forward and jumped up 1000 rpm and took off, it felt good for about 90 seconds, then bogged down and stalled 1000' off dock. Engine would crank over and sputter then stall. thankfully, my neighbor was sitting on his dock watching me and towed me back with his kawasaki (I always give him crap about his perfectly running kawi
) once back at the dock, I was able to get it started again, but very rough. I pulled it out and called HK Powersports in Hooksett, Nh- earliest service date may 23rd
. Looks like the MAP is under the ECM on the engine. The thought of taking the suspension off, engine cover & ecm just to change the MAP sensor makes me wanna vomit. just don't have the time to deal with it. I hope I don't have a defective intercooler! why am I so hooked on BRP? I've owned a dozen sea-doo's and can-am outlanders with 1000cc rotax engines- the atv rotax engines run flawless- my last 4 sea-doo 4-tec engines had constant issues!
