Kerlin
Mercury m2 240. Been fighting with her last 2 years. Or more. Please listen to the video and assess the sound. Is the knocking normal? I’m grasping at straws here.
Background: won’t plane out on water ( get above 4K rpm)
New parts
Air temp sens
Engine temp
Rev limit
Trigger
Stator tested ok
Cleaned vst filter
New primer filter
New fuel sep filter
New plugs
Spark on all cyl
Good compression on all cyl
TPS tests good
New battery
Volt reg tested in spec
36 psi on fuel reg
New bottle excedrin migraine
New exhaust hoses
New parts
Air temp sens
Engine temp
Rev limit
Trigger
Stator tested ok
Cleaned vst filter
New primer filter
New fuel sep filter
New plugs
Spark on all cyl
TPS tests good
New battery
36 psi on fuel reg
New exhaust hoses
