RFI (rotax fuel injection) system
Laze, when you say "is there something I can do" to make sure your ski doesn't leave you stranded, well, yes, there is. But trying to type all the procedures to do a tune up on your ski would take me a long time.
The RFI system operates from the MPEM and if you have no faults, then your fuel system may need to be cleaned and the component parts tested.
You have 6 parts to the RFI.
1. The fuel tank
2. The fuel filter
3. The fuel pump
4. The fuel regulator
5. The injectors.
6. Finally, the engine.
When you first put your lanyard on, if your in a quiet environment and you listen closely, you should hear your fuel pump come on for about 1 second as it charges your fuel system with 56-60 pounds of pressure.
This system was designed and used in providing optimum starting and operating conditions for the ski and the environment (due to reduced emissions).
This ski should start as soon as you hit the start button. If not, then you need service. Their could be a faulty check valve, fuel module, regulator, filter needs cleaning, or a whole host of things, including a weak fuel pump.
I can tell you how to clean your filter, but to test all the above components, would be to lengthy.
You can become a premium member for at least 1 month to have access to the manual yourself, then, after reading the chapters on your fuel circuit, be able to perform those tests yourself. If you get stuck, any premium member or moderator ( who are also experienced mechanics) can help you out.
Good luck, and let us know if you need something else.........:cheers:
