I have a pair of GTR 215s, upgraded with xChargers and Fizzle Intercoolers. Both run extremely strong and top out at 71 at sea level. One of the skis runs a little rough/chugs at idle and has a gas smell. Once you get going it runs as strong as the other ski and has the same top speed. Upon inspection cylinder 3 spark plug is a little wet and the top of the piston looks different than the other two cylinders (not as dry looking). I can't imagine the ski would run this strong if it was running on two cylinders. Is it possible it either misfires or doesn't burn all of the fuel at idle/low rpm and runs fine at higher rpm? There are no codes on the ECU.
