RogerS Member Jun 21, 2018 #1 I forget to mark the hoses before removing from the gas sender lever.... anyone have a picture or tell me how is the order to be re-atached? Thanks
mikidymac Moderator Staff member Moderator Jun 21, 2018 #2 It is typically molded on the sender, RES, VNT, ON & RES.
RogerS Member Jun 21, 2018 #3 mikidymac said: It is typically molded on the sender, RES, VNT, ON & RES. Click to expand... I saw that but dont know what that is and which hose go to it... VNT i guess means “vent” going to the hose at the vent on the side of the hull
mikidymac Moderator Staff member Moderator Jun 21, 2018 #4 RET is the return directly from the carbs. ON goes to the fuel valve if your boat has one then through the strainer/filter and then to the carbs. Not sure if the boats use RES reserve.
