Thank you, I did as you explained and it was perfect, but I didn't find my problem with the gauge as it is a sealed unit. Is there a way to check the connections in the console with a volt meter or continuity meter to tell if the gauge is at fault, I don't want to buy a new gauge if it is not the problem. I have already gone through the gas baffle in the tank and the magnets are good also the bottom filter is clean. My manual does not have any wiring diagrams in it, so I am kind of stuck. Again, thank you for your response.
Cliff
