backyarder
regarding my last post of ski bogging after 15-20 minutes and changing plugs and it runs good again, etc.
I thought about this logically. If after putting in new plugs and the ski runs great and then bogs down after 15 minutes, change plugs again, and it runs good again. what could be the problem? well, I was told to check my oil pump adjustment, and be sure to run the correct oil for my ski. I removed oil and then thought that I would check my fuel filter. the reason for that is that if the filter was clogged enough to drain gas into the line, but not open enough to run after the gas had drained out of the line, making the ski run lean and appear to bog.
after draining all the oil and gas out of the ski, and taken the fuel baffle out to check the filter.
one diagram shows a filter at the bottom of the fuel pump assembly and another just inside of the bottom (after the bottom piece is removed.)
another exploded diagram of the fuel pump assembly does not show the filters at all.
after removal of the fuel pump assembly, there was no filter at the bottom of the assembly. there may be a filter inside at the bottom, BUT....
here is my problem. how to take the baffle apart to get to the filters. the shop manual and the parts manual do not show it.
anyone with ideas?
anyone with ideas?
