Fuel / water mix under the motor
AndersLj
Hi
First of all, I'm new to the forum and was hoping fore some help
I have bought a 95 speedster twin rotax last year. Ran it this summer and its a lot of fun
now for the not so fun part.
I rebuild the carburetor on one of the engines and after installing the carb again was doing winterization on that engin.
Everything ran smoothly as expected.
But afterwards I saw something under the motor that looked like oil mixed with cooling water. If it was a 4-stroke engin i wold say that water was mixed with the oil and that it was a crack in the enginblock or something similar.
However now its a old 2-stroke engin sow I have now idé what it is.
During the carburetor rebuild I took the carbs off and also (by mistake) removed the intake manifold rotary cover.
I realized after the winterizing was done that I onley tightened the top bolts on the rotaty cover.
Cold this be the reason for the fuel oil water mix under the motor?
Best regards Anders
It is normal to have some oil and water mess in the bottom of these older boats/skis. One of the best cleaners for it is Castrol SuperClean available at walmart.
That looks like some fresh red oil so I would inspect your oil tank and all the oil lines.
