Fuel tuning
LawnDart
I've fixed the exhaust leaks on my 98 sportster and now its time to set the screws. Can anyone provide any guidance? Are these air screws or fuel screws on a 717? In is less fuel out is more?
I run the boat at 4200 ft and previously it was used at 6000+ ft. It is strong at full throttle but it goes the same speed at 2/3 throttle. Seems like one engine hangs onto rpm a bit after shutting off......might be lean on the low speed??? I've had a couple stalls but one engine idles at 1500 and one at 1000 rpm. What is the idle supposed to be set to?
