fuel stabilizer
alex1
How important is fuel stabilizer for PWC equiped with orbital injection? GTX DI
Does mixing oil with fuel during storage will reduce the possibility of gumming?
which has a higher possibility of gumming, low octane or high octane fuel? or irrelevant
thanks
Yes........
Yes, ........if your going to store any 2 cycle engine, it is highly recommended that you use a fuel stabilizer. Especially with the DI models.
Over time, fuel will become "gummie" or even harden like a "lacquer". If your only setting up for a few weeks, to even no more than a month, I wouldn't worry about it. But the engine should see at least 1 hour of running per month.
Thanks a lot seadoosnipe,
should i use only the bombardier stabilizer? or use any other fuel stabilizer?
what about the other two questions regarding mixing oil and octane?... if possible
