2007 Sea-Doo GTX STD (155) ... looking for additional assistance outside the couple of posts related to this issue. Current fault diagnosis / report is: P0463, Fuel level sensor circuit shorted to 12V or open circuit. I have cleaned contacts at both the fuel pump module, as well as the ECU contacts, confirmed continuity for both the ground and load wires from sensor to ECU. The beep warning is intermittent, but guaranteed to get at least a number of alerts on any ride. I have not taken out the fuel module and checked resistance of the float/sending unit, and/or just replace the unit, just a little reluctant to do that if there is a simpler solution that I'm overlooking for this specific fault alert. Welcome anyone's thoughts. (PS ... I was having a similar issue with the water temp sensor but cleaning everything up seems to have resolved that issue - regardless the fuel sensor is driving me batty). Thanks.
