It is handy to know the effects of what you are doing...
If the injector is working properly, I think it is better than pre mix.
Injector is a variable rate system.
At WOT, it is probably injecting around 40:1
At idle, it is probably injecting 100:1.
I'm guessing these numbers, but you get the idea.
This means that there is not a bunch of UNBURNED oil in the crankcase, after an extended "no wake" zone, like if you pre mix it.
So, if you pre mix it, you will have alot more smoke, and more fouled plugs. However, you can be sure it gets oil. (This is the main incentive to pre mix)
I favor a properly working injection system, over pre mix.
I favor pre mix over a broken injection system!
For a while, I'd stay with BOTH, until I determine what I really knew what I wanted to doo.
IF you decide to go pre-mix, watch this:
If you use 50:1 ratio, then your fuel mix is THICKER, (than straigh gas) and runs through the carb slower, resulting in LEAN condition, so, you re jet it, for the thicker fuel. Then, if you change and run 40:1, it is thicker still, and can go lean again, so, you wind up re jetting for 40:1. Then, you go back to 50:1, and you are too rich!
And, if you run lean, with a pre mix system, then it will now be running TOO HOT, and LESS OIL. This can cook a motor. Think in terms of Revolutions per cc of oil, instead of mix ratio.
With pre mix, (and a lean condition) you have a high reving engine, with virtually no oil, with alot of heat.
My personal taste is pre mix for a while, while you make sure the injection system is going right, and then go back to injection. And, adding a bit of oil to the gas WITH the pre mix system (say to 110:1) then you can be sure everything gets lubed.
Anyway, you will get info on both sides of this issue, and I hope I have given you some to think about.
Nate
