2UCS Member Jun 21, 2016 #1 I have a 1998 Seadoo Sporster 1800 with a broken Fuel Oil Gauge do i have to look for that year of boat or can i use from 90's boats and pwc's or is there some work to wire up from other years ?
Mask1 Member Jun 21, 2016 #2 I believe you could purchase 1 of the gauges from kijjii that was sent to you via text message
2UCS Member Jun 23, 2016 #3 Not the same ones that i had Hope someone could verify if i can use other model seadoo gauges.
2UCS Member Jun 27, 2016 #4 Can i just drop in a 1997 seadoo sportster Gas gauge and it work ? Anyone ?
snikwad003 Well-Known Member Jun 27, 2016 #5 If its the same size it will work you might have to re arrange the pins in the connector
