Karl I think me was asking if the whole motor needs to be removed or if you just remove the carbs? Right bz1mcr. I'm not 100% sure but I think you can its just tricky to get to the bolts that hold the carbs on.
Hey karl what's the best tool to use. Just a wrench or a small socket. I need to do this to my two Doo's and would like to know what your experience with this is.
15min no prob in boat, ski...WAY less room..bz1, if its the XP w/ 717, then shouldnt be difficult, the gtx, darn stud, need to pull the exhaust, if not, might need anger mgmt afterward...:banghead:
It is the GTX--It would be. So, once the exhaust is pulled you can get to the carbs to replace the lines and clean the carb filters? Do you need to pull the carbs to clean the filters?
Don
