I have just bought a 1999 Speedster with the twin 787s. One engine starts and runs but the other doesn't seem to be getting any fuel. The clear fuel filter going to that engine is not filling up. Since both engines are fed from the same fuel pump I assume it is not a pump issue but then I am not sure what would cause one side not to flow if the other is. A blockage is the most likely answer but before I go and pull all the fuel lines I thought I would ask if there is anything else I should be looking at first ?
Thanks
Thanks
