Russ46
Hey guys, so my 1997 challenger 787 stars and idles perfectly in the water, will rev up to 3000rpm then fall on its face. If I spray premix into the carbs I can get it to rev out all the way to 6500 and if I stay up aboove like 20mph I can let off the gas then accelerate back up to 6000rpm but once I get too slow or come to a stop it just cannot get past 3000rpm again without help!
I cleaned both carbs, set the mixture screws to factory, replaced plugs (after driving the boat and pulling the new plugs they look perfect, the fuel mixture looks awesome), I replaced the accelerator pump diaphram as it was leaking and I really thought that was going to fix the problem..
The boat has all black fuel lines, new in line fuel filter and new premium gas. It starts up instantly and will idle at 1500rpm in the water forever with no issues. Does anyone know what it could be? The only thing I didnt do was check the carb pop off pressures, could this be a symptom of that? Or could there be a fuel pump issue?
I am going to order a vaccuum pump and check my pop off pressures and I am even going to pressure test my fuel pump diaphragm.
