fuel/carb symptoms but not a fuel problem..please help
gcha1727
I have a 1998 challenger 1800 with the twin 787s. One motor runs perfect the other does not.
There is two ways the problem occurs. First, if I accelerate aggressively (low idle to wot)the motor will go from 1500rpms to 4-6k rpms and will fall back down just as fast. It will stall if I dont throttle back to catch it. Second, if I accelerate slowly it will idle perfect all the way from 1500rpms to 7k. Anywhere from 2-10 minutes after cruising at 5-7k it will fall off like I hit the start/stop button. Again, if I pull the throttle back quick enough, I can catch it before it stalls, idling back at 1500.
I was sure this was a fuel problem. I pulled the carbs and cleaned them thoroughly. It did not help.
I swapped all fuel related components from the good side to the bad..the carbs, fuel pumps, fuel filters, etc..still had the same problem with the same motor.
I also swapped the water valves on the exhausts.
Compression was checked 149 and 140. The one side has always been a little lower due to scoring from a while back.
Raves were recently cleaned and seem to move free.
Checked my waterlines for clear passage.
There is a little water in the bilge that I cant tell where its coming from. Im not sure if its related to this problem. I dont think its coming from the drive shaft. I cant find any leaks on the exhaust and or motor.
What direction should I take this ???
Thanks for the help...
If it's dropping out, and you can catch it... that's fuel. (or related)
When you swapped the parts around... did you also swap the pick-up hoses? (the fuel feed) You may have an air leak in the fuel select valve.
