Fuel Baffle Repair-Now what?
specagntscully
Hi All,
Great place for information.
I performed the F1 fuse removal and hard wired, plugged back in and now I
get 1/2 and Full readings only.
Plugged the baffle back in and put in key and gauge goes to 1/2 full. Tilted the baffle slightly and now it
reads full.
Gauge will not go under 1/2 full and never reads empty until the key is removed.
Is there something I am missing? White puffy Float and magnets look all intact.
Thank you in advance for any advice you can offer.
I did not replace the float as both magnets seem to be intact. As I tilt the baffle back
and forth it seems that the float does move all the way from top to bottom. I remove
the bottom cover and float slides right out with no problem.
With the float at the bottom of baffle it still reads 1/2 full.
I will order a new float to see if that works.
New Float-still issues
I purchase a new float and still have the same issues.
Do i need to place it back into the tank to get fuel on it
to see if it works properly?? or should I now replace the baffle unit.
thanks for your help.
