JAYSONFLYNN
Thanks for any responses! Rebuilt the entire 717 1996 GTI (has hour on it after the following), including SBT Rotary valve and plate. Rebuilt carbs twice, first with cheap kit and then with MK genuine parts. Carbs are in synch x4 attempts. Just got back from the lake, pre-set the low speed to 1.5 turns out, running 32:1 with oil injection delete, just Klotz Ski Craft premixed. Initially ran like crap before the top jets kicked in, ran perfect on top jets from 1/2 to WOT throttle. Adjusted the low speed several times, up and down, kept getting worse, had to feather it or give it slight bit of choke. Could feather the throttle up to the top end jets and it would come alive. That's first problem... secondly it started blowing the 5amp fuse? What the heck is going on? Thanks everyone for suggestions!
