Easy fix
That tends to be a pretty quick fix on these boats. If you have a look at the ride plate under the nozzle you will notice it is adjustable. Just loosen the jam nuts a adjust the plate to it's lowest position....... problem solved.
Everyone I've talked to has been able to put an end to their porpoising problem with this adjustment, but also be sure to pay attention to how you load your boat. Do not try to keep all your gear stored at the back of the boat, but rather spread it evenly around, or bias it toward the bow a bit.
Aaron:cheers:
