SurfBeat
Dumb. Late at night I arrived in Parker, AZ, temperature 115. First ride since last October.
Unloaded the Jet Ski's for the night.
Next morning, although the Kawi's would crank, they would not start.
Upon removal of the seat I saw the engine compartment was half full of water, a few inches below the carb, but covering the electrical box. Water did not reach batteries, nor did water enter engine.
It was apparent that in my haste to unload my Kawi 1100 STX's, I forgot the drain plugs were left open.
I loaded the Kawi's on my trailer, drove to a steep hill to drain the water.
I let them dry out for a few hours, then both Kawi's cranked over. We rode them hard for two days, then this afternoon, after a ride in the early morning, with temp at 115, one cranked over intermittently several times, then would not crank over.
The other Kawi would not crank over. Both acted as if the batteries were dead. Both have 12.3 readings, so they check out okey dokey.
I opened the electrical boxes and both were 1/4 full of water, wires submerged in water. I mopped up the water and am letting them sit in the sun to dry out.
QUESTION: Am I diagnosing the problem correctly?
I am figuring that since they ran for a few days after being submerged in water overnight, then water accumulation in the E boxes is causing a bad connection somewhere. Right?
I doubt I could have ruined anything, right?
My idea is to head to Wal Mart, fetch me some electrical spray to clean the connections, then re-assemble. Am I on the right track?
Suggestions welcome, other than calling me DUMB, which I acknowledge.
No water entered the engine.
