Forgot to plug into Grounding post
I started the ski in the driveway tonight to make sure everything is good for the lake tomorrow.
I started it, ran it for about 2 mins on the hose. I shut it off. Seemed weak. Realized what was wrong. I forgot to put one of the spark plugs wires on the plugs. Put the other wire back on, started again no problem, sounded much better.
Should I get another ignition coil? There are 2 in the black box. How can I test it? I read they usually get fried if you don't ground it out.
Any comments?
It's possible that it arcked and didn't cause a problem. Run it if it runs ok don't worry about it.
Karl
