Mechanicallychallenged
I have a 717 with a stuck fly wheel, I tried puller on it and it won’t come off, is it OK to use a little heat on it or is there seals that may melt?
Or is there a better option
Thank you for the detailed response, I will try the tapping first I’m trying to get it off without pulling motorA little heat is OK. Have the puller on and tightened down so you have tension built up. At this point, before the heat, you can take a hammer and give a tap on the big flywheel bolt that is pushing against the crank end. Not a hard hit, but a short, sharp tap to send a shock into everything and that might be enough to pop it off. Give it a tap and see if the puller will tighten down any more, do this a couple of times, tap with tension. If things are still not letting loose then leave the puller in place with tension and heat the flywheel a little, try the tap again. You want to use as little heat as possible. DO NOT slam the hammer with any muscle, just a gentle swing as straight into the puller as you can.
Was having trouble with it running the last time I had it out on the lake. Wouldn’t do over a. Few MPH so I changed gray lines and rebuilt carbs. Now it won’t start.Okay,,,why are you pulling the flywheel if the motor is in the hull?,,,put tension on the puller,,,heat the flywheel,,,buy the loktite website,,,you need enough heat to melt the red loktite,,,assuming someone put on a lot,,,be carefull with the shock tap,,,it can deform the head of the puller bolt and your socket
Could be flooded. That would also explain the backfire.That’s what I would think too. But why wouldn’t it not try to start if I primed it. Even after sitting for a day ?
Pull the sparkplugs and check for spark
I did not pull the flywheel!Could be flooded. That would also explain the backfire.
Pull the sparkplugs and check for spark.
I did not pull the fly wheel but I did get it to start on the trailer, it’ll Idol a little bit if I give it Throttle it backfires through the carb and diesDO NOT pull the flywheel. Look at the fuel system.
Explain pleaseSounds lean,,
ThAnk you for the detailed response it is greatly appreciated, I got it to fire up a few times and dies sometimes it backfires through the carb. I do not have the flame arrestor on.Flooded motor shut the fuel off then pull the plugs put a couple rags over spark plug holes put your plug caps on the grounding post so you don't explode.pump out by turning motor with starter with the throttle wide open.do that at 30 second intervals so starter and wires don't get hot and go boom.then with the fuel valve still off put plugs back in hold wide open try and start it.keep holding wide open till it runs.make sure your flame arrestor screen is still on
