Toolanddiemaker
ok so I finally got the engine pulled and my crankshaft is shot you guy's were right,off for rebuild:facepalm: anyway I got the pto off and the flywheel nut but the flywheel wont budge and is frozen I put the universal puller on it and was using an impact wrench but its not moving. can heat be applied or will that ruin the magnito? I will also let it sit overnight with pb blaster and a little bit of tension. thanks
