Wolverine
Hey y'all: I am in the process of rebuilding my 2001 XP, it sat under tarp for 11 years, but after rebuilding carbs, flushing and cleaning engine, fuel lines, exhaust, etc... shockingly the darn thing started. Ran it a couple times (7 seconds, then rest for an hour, restart) to make sure it would keep starting. Now, I'd like to hook up a hose so I can run it for longer periods (60 second intervals) to check for leaks, fine tune, before a full lake test. The 2001 Seadoo shop manual (page 43) shows hook up is to the top left of prop. A seadoo video (of later models shows hook up to right). Attached is a picture of my rear housing, #1 labeled on the picture is a connector (female, threaded) on top right of prop, #2 is a female connector threaded on top left of prop, that has a bracket slightly blocking any access. #3 is a female outlet no threading on lower right. Is the top right (#1) the correct to flush? Are the others exhaust ports? Next question... Though the rebuild seems successful, the engine seems to be running at extremely high RPM when I start. I checked the carb throttle line (cable from handle bar, down to pully under carb, seems to be engaging and retracting proper and fully. Any thoughts? Low idle screw set too high? And thanks in advance for your guidance, this is my 1st (jet ski) rebuild.
