cli55er
well, i wanted to beable to flush both of my engines at the same time. yeah, i am lazy when it is hot outside.
so, i went to Lowes and bought these pieces:
1. 2x 1/2" female garden hose end repair kits $1.65 each
2. 2x On/Off valves male to female $2.65 each
3. 1x dual engine flush hose (this was on clearance at Academy) regular price was $29 dollars, but it was on clearance for $6.88. SCORE!
cut off the seadoo proprietary pieces and put on the garden hose repair kit. cut slits in the stock sealing boot for the hole in the boat. cut off one of the ears you make while cutting the slits to make room for the valve. feed the valve through the rubber boot and then screw it to the hose repair end you put on already. shove it back through the hole and you are good. turn the valve to off when not in use.
connect the dual flush kit and go for it. ;0) or if Academy doesn't have it for that cheap, do one engine at a time.
so for about 17 buck, i can flush both of my motors at once. ;0)
nice.
nice.
